5G - a new era of development in mobile communications
The abbreviation 5G refers to the 5th generation of mobile communications. In the 5G network, data can be processed at an enormously high speed - significantly faster than with today's 4G/LTE standard. On the technology side, 5G transmits data in the same way as 4G and uses the same frequency ranges at 2GHz. In addition, 5G relies on a new frequency range with shorter waves (3.4 to 3.7GHz). The simple rule applies: The lower the frequency, the greater the range. In higher frequency ranges, on the other hand, larger volumes of data can be transmitted.
In the opinion of many experts, the future belongs to the mobile communications standard 5G. Large bandwidths, low latency, real-time capability, nationwide availability, and high reliability are just some of the advantages offered by the new standard. As a central aspect, for example, 5G technology allows the implementation of individual, virtual networks that are specially adapted to the requirements of users. These are operated under the common 5G infrastructure. In this way, the needs of industrial users can be better addressed in the future.
